Hello everyone, I'm fairly new to Radioss and I'm simulating a drop analysis of a rigid dummy head in a bicycle helmet with a liner consisting of an elastomeric lattice liner instead of a foam liner. For the moment, the liner is modelled using first order beam elements for testing purposes and the material behaviour is linearly elastic. On to the questions:
1. How can a selection of 1D-elements be split (preferably n times)? Some TCL scripts can be found via Google, but they did not run correctly. The link to Script #1013: Split 1D beams mentioned here: https://insider.altairhyperworks.com/scripts-of-the-month-5/ leads to the signing in page and then not to the right page.
2. I noticed that with a type 20 interface and default Stfac of 0.1, the rigid dummy head (master) is penetrated severely by the lattice (slave). Increasing the Stfac to 100 or more remedies this, but seems to artificially stiffen the interface way too much. I'm aware that this is the intended behaviour, however how can the right balance be determined?
3. How can a large amount of energy loss during a simulation run be remedied? Depending on the lattice thickness, up to 50% seem to get lost.
4. What's the cause of a mass change of >10% already present in the first calculation cycle?
