I am running an impact simulation between a rigid plate and a lattice material and am attempting to distinguish between elastic and plastic absorbed energy in the material, but it seems as though I can only look at the total internal energy (which I assume has both plastic and elastic components). Is there any way to "split" the internal energy into the elastic and plastic portions when looking at the part / material as a whole? Or perhaps there's an alternative way to calculate the elastic and plastic internal energies over time using data from either the T01 and/or .h3d files?
(The model was created in Hypermesh, run through Radioss, and I am using HyperView/HyperGraph to post-process).
