Dear All,
I am trying to use EDEM's Tavares UFRJ Breakage Model to simulate the fracturing behaviour of particles (3-6 microns in diameter) under compression (subjected to pressures of about 30-300 MPa). When I try to use the GPU for CUDA solving, the particles fail to break up no matter how much I adjust the simulation step size and stress loading rate. However, when I try to switch to the CPU solver with the same parameter settings, the particles can experience the breakup behaviour as expected.
I am very confused about this, and I am wondering if I need to make some special configurations for the CUDA solver when using the Breakage Model. Where should I consider adjusting my model to troubleshoot the problem?
Some model-related configuration:
contact model: EEPA
contact radius: 1.5x
time step: 3e-11s
computing platform: NVIDIA RTX-4070
Thanks,
Jiashen Chen
