I am measuring the frequency deviation in a microgrid operating in islanded mode during load changes. Currently, I use a Phase-Locked Loop (PLL) block to measure the system's frequency. However, despite following the PLL Help instructions for calculations, I notice significant ripple in the frequency output (as shown in the attached image).
Are there alternative methods to measure the system's frequency through the voltage or current waveforms? If not, how can I reduce the sinusoidal ripple in the PLL output? I have already tried applying a Low Pass Filter (LPF), but while it attenuated the oscillations, it also dampens the frequency deviation (e.g., without the LPF, the minimum frequency is 49.2 Hz, but with the LPF, it is 49.3 Hz).
