Facing issue of Fatal Application Error while installation of Altair Student Version on windows 11. I set the environmental variables as JAVA_TOOLS_OPTIONS = "-Dos.net=Windows 10" . Still facing the same issue.
Requested to give solution
Please note that the java installation issue you are seeing is caused when trying to install a v2022.1 Altair product on a Windows 11 environment. Windows 11 is not an officially supported platform yet. Official support will come soon.
Setting a system variable as below should work usually:
Please follow these steps in order:
1. Uninstall the software.
2. Set the system variable (as shown above).
3. Try to install the software again
Please let me know if this works.
Please note that the java installation issue you are seeing is caused when trying to install a v2022.1 Altair product on a Windows 11 environment. Windows 11 is not an officially supported platform yet. Official support will come soon. Setting a system variable as below should work usually: Please follow these steps in order: 1. Uninstall the software. 2. Set the system variable (as shown above). 3. Try to install the software again Please let me know if this works.
Dear Payal Pawar,
It's not working. Same error again after following the suggested steps.
regards
Dear Payal Pawar, It's not working. Same error again after following the suggested steps. regards
Are you sure you have created the environmental variable as mentioned above, and as system variable and use the " "?
Yes Sir,
Did you uninstall the software before setting the system variable?
it is JAVA_TOOL, no TOOLS
Thanks a lot to Payal & Adriano.
I corrected the mistake and its working perfectly.
Nilesh
Yes i did a mistake to define environmental variable
its working now
thanks a ton
