Cooling simulation by Optistruct.
As we can perform steady state or transient heating phenomena through optistruct, Is it possible to perform cooling phenomena also ? I tried in many way but results are not up to mark. As i thinked cooling of outer layer will be higher then inner layer will cool slowly & max temp should be in the mid, & temp should decrease exponentially according to theory...and all... But nothing simulated like that/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
One of fem file which i tried, uploading here. Plz help if u know.
This is what i got. I defined temp loading only for 10 sec, total sim time is 300 sec.
just after 10 sec whole block temp is equal to surrounding temp (in my case i defined 300 K)
