I want to do a 2d modal analysis with the attached model.
Inner diameter: 20 mm
Outer diameter: 30 mm
Real thickness: 10 mm (but of course the model is flat)
I used the PSHELL property with thickness = 10 mm, so there is no actual third dimension.
When I look at the results with hyperView, I found some 3D modes like the shown one.
Question:
How can I tell hypermesh / optistruct, that I my problem has 2 dimensions only and that I want to analyze only the xy plane?
Thanks for your help!
