Hey everyone!
I am having an issue importing geometry in the STEP format. Unfortunately, the loading process gets stuck at 1% and doesn't progress further. Even the model I had successfully imported into EDEM is now not getting loaded. I've tried it on three different software versions and change a lot of unit, but the problem persists.
If anyone has any idea what is causing this issue, I would be grateful for your help!
Thanks a lot!
MTA
