I am trying to map the pressure values from .log file. of Cfd, in this section what type of interpolation should I choose for pressure type. Please help me, thank you.
Hello Tao,
You can choose the interpolation type based on the three options defined below. You can choose shape function if your mapping the results as is.
Shape function (based on mapping) Proximity (based on close point evaluation) Linear interpolation (based on inverse distance)
Thanks
Rajendran
