Hello everyone,
I'm trying to perform a non linear buckling analysis on an inflatable pressurized tube.
I set a satisfying model in Optistruct using PSHELL elements (with a MAT1 material) with a NLSTAT-LGDISP analysis, and it matches well experimental points also in post-wrikling state.
Now I would run a non-linear buckling analysis in order to predict the maximum axial and bending load on the beam, so I found that only with Radioss it is possible. Next, I would be interested in modeling the folding and unfolding of the beam in an appropriate box in order to simulate the behaviour.
The questions are:
1) am I right? are there example about modeling of inflatables in Radioss or should I use another product? It is possible to run a non-linear buckling analysis with Optistruct?
2) I'm new in Radioss: are there some tutorials about folding and unfolding of inflatables by increasing of pressure? It is necessary to model a fluid-structurer interaction in this case?
Thank you for your attention
Andrea
