I found that Simlab often had software crashes and automatic exits during pre and post processing(especially when the mesh amount is large). For sxample,just now, I happened to encounter another software crash, which occurred in the process of opening "Results" after a 5min local calculation,when Simlab is used for fluid thermodynamic simulation calculation.
I want to ask the possible reasons why this often happens when simlab is used for fluid thermodynamic simulation.
Thanlk you!
