I have a question about how to correctly apply a load to an RBE2 which connects to the nodes on the inside of a hole.
If this RBE2 is representing a bar in the hole, then the force should only be applied to the nodes which are under compression by the bar (in front of it marked green in the image) From what I have seen, it applies the force to all nodes selected since they are all selected. (doing as its being told to).
Is there a way to only have force applied to `arms' of the RBE which are in compression (being compressed by the bar) and anything in tension has no force applied?
I suspect there must be a better way to do this, but I can't see/find anything.
Please see the image for reference.
Thanks in advance for any help!
Anthony
