ANY SUggestion for this error plz:
Hi oggy,
I am not really sure about the model, but my suggestion would be reacting the rigid element ID= 13031726 again.
thanks i will try this solution
MESSAGE ID : 110 ** ERROR : RIGID BODY ID=90812 UNSTABLE ERROR TERMINATION I'm getting similar error. Please tell me how do I react the rigid element ID=90812
The rigid body turns more than one radian per cycle. This situation is due to divergence in the computation.
Please select this rigid body from RBODY MANAGER in HyperMesh and make Ispher to 1.
Hi, The rigid body turns more than one radian per cycle. This situation is due to divergence in the computation. Please select this rigid body from RBODY MANAGER in HyperMesh and make Ispher to 1. . <?xml version="1.0" encoding="UTF-8"?>
Hey George,
I get the same error message, even though I set Ispher to 1 and tried to do the rotation of 45 degrees (0.7853 rad) around all three axes in two steps per axis. Any idea on what the problem might be? Thanks in advance!
Edited to attach files with defined units.
@rea2
which units did you choose? i don't understand.
@rea2 which units did you choose? i don't understand.
Thank you - totally forgot to chose units. Did that now, but I still get the error message
i see.
i have taken my units, but it was not cause of error.
i am still trying to solve these issue=)
i see. i have taken my units, but it was not cause of error. i am still trying to solve these issue=)
Thank you! Reducing the angles to 0.5 helps, but that's not what I want...
i don't like and understand how to work rbe in radioss.
i have done it like this=)
i don't like and understand how to work rbe in radioss. i have done it like this=)
Thank you for your effort! However, I need to keep the rigid body, I cannot solve the problem by just removing it.
Anyone else? I keep getting this error message from time to time, but unfortunately cannot identify the problem.
you can do RB instead rbe+shell because your rbe+shell=rigid body=)
It is always better to use Rigidwall instead of using shlle+rbe to make it rigid, especially when you have contacts.
