Adjust Node Selection Size in HyperMesh 2020
Blake Berk
Blake Berk Altair Community Member
edited January 2021 in Community Q&A
The new 2020 shrinks/enlarges node size when zooming, compared to previous versions that fix the node size on screen. Is there a way to switch back and forth? Is there a way to change the node size scale?
My model is quite large so the selected and temp nodes are too small to be usable.
Thanks!
Best Answer
  • Viraj_Kulkarni
    Viraj_Kulkarni
    edited January 2021 Answer ✓
    Hi Blake,
    Use turn on/off of “Node level of detail” option to see the change in visualization size of temp nodes. (Preferences -> Mesh/Geom Appearance)
  • Viraj_Kulkarni
    Viraj_Kulkarni
    Hi Blake,
  • Blake Berk
    edited January 2021
    Hi Blake,
    Thank you!
Welcome!
Welcome!
