🎉Community Raffle - Win $25
Join and Win
Adjust Node Selection Size in HyperMesh 2020
User: "Blake Berk"
Altair Community Member
Updated by Blake Berk
Hi,
The new 2020 shrinks/enlarges node size when zooming, compared to previous versions that fix the node size on screen. Is there a way to switch back and forth? Is there a way to change the node size scale?
My model is quite large so the selected and temp nodes are too small to be usable.
Thanks!
1 - 2 of 21
    User: "Viraj_Kulkarni"
    Altair Employee
    Accepted Answer
    Updated by Viraj_Kulkarni
    Hi Blake,
    Use turn on/off of “Node level of detail” option to see the change in visualization size of temp nodes. (Preferences -> Mesh/Geom Appearance)
    User: "Blake Berk"
    OP
    Hi Blake,
    Thank you!
