In a postprocessing attempt, I use "GetValueList" command from contour handle.When I use this handle, the hyperview window crashes.Would like to know more on the limitations of this command
please let me apologize for our late answer.
This may be linked to some memory leak. That said, it is generally recommended when dealing with Contour query to use the Query or the QueryIteratorCtrl Handle.
Hope this helps,
Michael
