I would like to know about the fiber breakage in Compression and Tension mode after the impactor impact the composite plate (G400), how can I get the results like this in Radioss?
you need to provide the failure limits to your fiber material in your model, according to the measured data.
Or add a Failure model on top of your material model.
Of course, it would be nice to calibrate your material allowables first.
Also for a more complete view, you could couple MultiScale Designer to predict more accurately the failure of matrix/fiber..
Some examples (not exactly for your application) can be found in the help of Radioss, under Example Guide>
