Hi all,
I am attempting to run a transient response analysis which applies a sinusoidal 1g acceleration peak to peak over a sweep of 15 Hz to 50 Hz to 15 Hz. The total cycle is 1 minute.
Is there an example with transient by Fourier transform method somewhere in the documentation?
I can't find a way to define the load as above; especially the up and down the frequency range part.
Thank you
