Selection of Best Optimization Algorithm
Nahid3007
Nahid3007 Altair Community Member
Hello community,
I got a little bit confused while reading the OptiStruct 2017 User’s Guide.
There I found that OptiStruct selects automatically the best optimization algorithm. Five items have been listed there (page 10-11):
- Optimality criteria method
- Convex approximation method
- Method of feasible directions
- Sequential quadratic programming
- Advanced approximations .
My question is: Does OptiStruct still selects the Optimality criteria method automatically? And for which type of optimization? There is no information about it in the User’s Guide or Reference Guide.
I want to optimize the topology of the 2 dimensional MMB-Beam (see atteched figure). My objective is to minimize compliance subjected to a volume fraction constraint.
I found that for my type of problem I shoud use 'OPTMETH=DUAL' since I have a large number of design variable and only one constraint.
So I cannot choose the Optimality criteria method in topology optimization?
Many thanks in advance
Nahid
Welcome!
  • Altair Forum User
    Altair Forum User
    edited July 2018
    The default optimization algorithm is known as the Method of Feasible Directions (MFD),
    From OptiStruct help:
    The DUAL algorithm should be used for concept-level optimization (Topology, free-size, and Topography) since such problems typically involve a very large number of design variables.
  • Nahid3007
    edited July 2018
    Yes I have already noticed that.
    But I am still confused whether OptiStuct generally uses the Optimality criteria method or not as mentioned in  2017 User’s Guide (see attached figure)?
    Regards
    Nahid
  • Altair Forum User
    Altair Forum User
    edited July 2018
    HI,
    I will check and update you soon..
  • Nahid3007
    edited August 2018
    HI,
    so do you have any updates whether OptiStruct uses the  Optimality criteria method  as mentioned in  2017 User’s Guide?
    Thank you!
  • Altair Forum User
    Altair Forum User
    edited August 2018
    OS selects the best algorithm for a given optimization problem. OC might still be activated when the design switch (T0 on PSHELL) is on (no DTPL/DRESP).
  • Altair Forum User
    Altair Forum User
    edited November 2018
    I am optimizing the radius of the lattice structure. How can I use other optimization algorithms? For example, Method of Feasible Directions (MFD), Adaptive Response Surface Method (ARSM), Genetic Algorithm..., and what is the  default optimization algorithm?Thank you very much!
Welcome!
Welcome!
