Hi there,
I tried to perform a study on a hypermesh file in hyperstudy but this error popped up when I tried to run definition.
*** ERROR # 1484 *** in the input data: Field 5 contains embedded blank(s).
can anyone help me out?
Thanks!
Hi Sylvester,
In PLY definition the 5th field is for "THETA" which is ply orientation angle. Default value is zero. I can see in the image it is 0, but please check if the fields are correct.
Also the fourth field looks to be blank which is for thickness.
Can you please verify and do the changes?
Thanks
Rajashri
