I am comparing the results from two studies:
1. A nonlinear static analysis with a preload using CNTNLSUB
2. A nonlinear static analysis with NO preload
(The cases are identical with one using a preload case)
My problem is that the results from the two cases are different for all load factors 0.1 through 0.9 (as expected), but on the final load factor (100%), the results become identical. Or in other words, the final load factor the Case 1 matches the final load factor for Case 2 which should not be true.
Would anybody happen to know why this is happening? Thank you for the help.
