I wanted to understand on how to arrive at the value for "Wear constant" under "Archard wear model parameter values" for a particular equipment material (in my case it is steel and carbide).
I was running a simulation for mixing of Iron ore, coke and limestone. I wanted to know the deformation happening on the mixer blades and I went ahead with using Archard wear as a built-in source in physics section and when the simulation completed the blades were deformed abnormally, I wasn't sure about the wear constant to use so I went ahead with 2e-08 Pa^-1 just to see how the deformation happens. Help on this is much appreciated. Thanks.
