Dear all,
I am working with Modal Frequency Response Analyses (MFRA), to be used for subsequent acoustics analysis. I am using customized acceleration signals, that were converted from time domain to frequency domain, as an input signal. I have set up the boundary conditions at the load application point according to the HyperWorks tutorial.
In the direction of load (here: x), I have entered 1,0. The other DOFs are constrained, thus entered 0,0.
From static analysis, I know that entering a number value (>0) in the DOF-field means "displacement by a certain value in the respective direction" (here: 1 [mm] displacement in x-direction).
However, when looking at the results, this definition seems not to apply to MFRA, as the model can move freely along the x-axis.
My question is thus: What does entering a value (e.g. 1,0) in the DOF setup mean in the context of MFRA? Is it a scaling factor of the input signal ? And what is the difference between entering a number value (>0) and leaving the field completely empty ?
I would be very happy if someone could answer my questions.
I'm looking forward to your reactions and thanks a lot in advance.
Best, Fabian
