Hello everyone,
May I know how to run Flux job on Linux CentOS command line?
Thank you
Hello Alpha,
In Altair Flux documentation you will find a “how to” devoted to this subject: go to Flux help in the supervisor -> pdf documentation -> 03_HowToLaunchFluxviaCommandLine.pdf. There the options to launch Flux from Linux command line is fully explained.
In general lines, if you want just launch Flux from command line, you should provide the path to the flux “exec.” file. On the other hand, if you want to change some parameters I advise you to see the different options explained in the documentation.
Best regards,
