I work for Sikorsky Credit Union, and I realized that the new version of Monarch has been released. Will our current licenses work on the latest version of Monarch, which is Monarch 2023, when I install the application?
It depends on what licensing method you are currently using. Here are the options in v2022:
If you have an activation code, it cannot be used with v2023 because the license server it is used against is no longer available after May 1, 2024 (?...not sure about the end date).
If you are using Monarch License Server, it should still be okay. Ideally, everyone should be moving over to Altair Units (either hosted or on-prem).
Here are the options for v2023:
It depends on what licensing method you are currently using. Here are the options in v2022: If you have an activation code, it cannot be used with v2023 because the license server it is used against is no longer available after May 1, 2024 (?...not sure about the end date). If you are using Monarch License Server, it should still be okay. Ideally, everyone should be moving over to Altair Units (either hosted or on-prem). Here are the options for v2023:
I see. Okay. That makes perfect sense. I have the updated procedure on how to install the latest version. Thank you very much for your assistance.
