Hi! I'm having trouble giving inputs to the motors in my model through Activate. The model runs perfectly in MotionView, but if I try to do a cosimulation of the model using Activate, nothing seems to change the motion analysis.
I've attached a screenshot of Activate along with the xml file and the Inspire model. I tried giving an input of 100 to the angle motor in the Inspire model, but it always moved upto 45 degrees only (as given in inspire). I set several inputs but nothing changed the run analysis. I understand that in MotionSolve, you can use VARVAL() as an expression along with solver variables to enable Activate to control inputs to the motors. I tried using this method, but it didn't work or perhaps I'm doing something wrong. How do I solve this issue?
Danie
