I want to minimize volume of a composite part but then after convergence i also want to see the total mass of the component.
How can i check that?
Thanks
Moeen
Composite optimization should be done in three phase using OptiStruct.You can refer to below online tutorial.
OS-T: 3200 Design of a Composite Aircraft Underbelly Fairing
Refer webinar on composite optimization as keyword in Altair University Learning library.
https://altairuniversity.com/learning-library/
For non composite material, the ideal way to check the change in mass is once the optimization is over is do an OSS smooth on the model and check the mass in HM through Tool-->mass calc and select all the elements.
just a general question. how can i find all my posted questions in altair forum? is there a place where all my asked questions are saved?
All posted question will remain in forum. To track your activity you can use activity tab. PFA screenshot for the same.
All posted question will remain in forum. To track your activity you can use activity tab. PFA screenshot for the same. <?xml version="1.0" encoding="UTF-8"?>
I don't have this activity icon under my account
where to find it?
Sorry I just realized that this options is available for admins.Please use my profile option to check the topics you posted in forum.
