Hi, experts.
I have the following two questions.
(1) In AcuSolve, the wall function can be selected in the model using SST k-omega turbulence model. In this case, will the calculation near the wall be performed using the wall function instead of k-omega, and will the result be the same as the standard k-epsilon?
(2) When a wall function is applied and there is no calculation point between the wall surface and the buffer layer, how is the flow in the first mesh layer near the wall surface calculated? Is the entire first mesh layer considered to be a turbulent layer, and is the logarithmic law of the wall function applied?
