Good morning dear all.
Look I am doing a simple three point bending of a sandwich panel (skin, core, skin) the core with the skin are attached using FREEZE, the material used is an isotropic one, using TABLES1, I used the curved with CSV format. I set my density, young modulus, and Poisson ratio, I DID NOT SET THE YIELD STRESS, because I have curve right? (I am doing nonlinear analysis, nonlinear static)
Well, when I start the simulation, it seems everything goes right and converging, until this error appears.
"zero or negative yield stress encountered. nonlinear analysis cannot proceed. this issue may occur if the hardening parameter H is negative".
How to solve this?
Thanks in advance
