Fatigue Life calculation on asymmetric cycle
tonystark
tonystark New Altair Community Member
trying to calculate how optistruct gives results about fatigue.
I've tried with an easy loading before, symmetric cycle with R=-1 and TABFAT 1.0 -1.0 and it gave me the correct sigma_range. I used 415 as UTS on Hypermesh to generate the wohler curve, giving me SR1=1769,15 b=-0.125. Using the formula Nf = (2*SGVON / 1769) ^ (1/-0,125) I found the cycle number obtained by Optistruct. Where SGVON is the value of the sigma obtained on Hyperview.
Ok then I've tried an asymmetric cycle with TABFAT 1.0 -.5. I've read the stress and using Goodman formula I should have 1.6M cycles...giving a wrong result. Instead Optistruct tells me that the element survives 18224 cycles.
I read for example sigma max = 286MPa. Sigma Min 143 (it's the half of the max..)
Sigma alternate=71
Sigma mean=214,5
sigma ultimate = (415MPa)
Goodman = sigma alternate / (1-sigma mean / sigma ultimate) = 148MPa
Sigma (range) = 2* Sigma (alternate) = 296MPa -> giving 1.6 million cycles??
How do I calculate this value in case of asymmetric cycle? (-1<R<0) ? What am I missing?
Thanks in advance,
Antonio
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2019
    Can you share the .fem and .out file ?
  • tonystark
    edited June 2019
    not needed anymore ..thanks :). It was just a simple supported plate. I've found my calculation error...I was using the sigma amplitude in Goodman formula..not Sigma alternate as I wrote here. Doing that I get the same number of cycles that Optistruct gives. Now the problem is that I need to do a dynamic fatigue calculation. I've received an acceleration time history in an RSP file and a # of cycles that the profile must be repeated. Can I use only Optistruct 2017.2 to solve this problem with latest Hypermesh 2017.3 ?
    Shall I do a transient analysis before and then a fatigue subcase calling the transient analysis?
    Thanks
Welcome!
Welcome!
