WARNINGS no warning. ... Geometry checked executeAlgo_c : Execution failed.Failed execution
To import the DXF file in Flux:
Flux 2D
Open a new Flux project
From the tab select project
Select import >> import geometry >> import geometry form a DXF file
Flux 3D
About the import options, if your DXF file contains only faces you need to select import free faces form the entities.
If the problem persist, can you send as your DXF file.
Best regards.
