TSTEP is automatiocally adding in nonlinear quastatic analysis
mpvnaresh
mpvnaresh Altair Community Member
Hi
I am rinning a nonlinear quastatic analysis . I am putting it for solve its giving an error
 *** ERROR # 1461 *** in the input data:
 Card 'TSTEP(TIME)' is not allowed for this subcase type.
 the input data TSTEP is adding on its own .how to deactivate this .?
  • Simon Križnik
    Simon Križnik Altair Community Member
    edited April 2019
    there is no TSTEP entry for nonlinear quasistatic analysis. Make sure you are choosing the correct analysis type- it should be non-linear quasi-static not generic.
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited April 2019
    Check this video also. See the load step creation after 8:00 min
  • mpvnaresh
    edited April 2019
    Sir i am not adding TSTEP s I t is automatically adding up in the deck file .
  • Simon Križnik
    edited April 2019
    The NLPARM and TSTEP load collectors share the same ID (3). Each LC needs a unique ID, which might be causing the error.
  • mpvnaresh
    edited April 2019
    But i am not adding the time step . I dont know why it is adding in all the solutions.
    When iclick on optistruct to solve ,In the deckfile TSTEP is being created.
  • mpvnaresh
    edited April 2019
    After i deleted the .tcl and hm.setting files from My Documents the problem got resolved .
    Thanks for the support.
  • FaroukM
    FaroukM Altair Community Member
    edited April 2019
    Hi
    Hi !
    TSTEP is for transient analysis.
    If you want to run Non Linear Quasi Static Analysis, NLPARM is sufficient :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Best regards ,
  • mpvnaresh
    edited April 2019
    Hi All
    I did not create any TSTEP .I created a Non linear Quasistatic solution ,and exported(solver deck file).
    In the FEM file i observed a TSTEP card  is added.For all the solution (Liner or Nonlinear )TSTEP is automatically added in the deck file.
    After i delete the .tcl and .settings file from the documents , The problem got resolved.
  • Deepak525
    Deepak525 New Altair Community Member
    edited August 2019
    Pleace help me to solve this problem
    tried this step also it doesn't work  kindly help me
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited August 2019
    Please make sure to set the analysis type as nonlinear static instead of generic in loadstep.
