I am confused about the role of contact radius in calculating contact force and contact detection. Currently my understanding is that contact forces are calculated based on particle physical radius and contact radius are only used for contact detection. For example, if I have two physically overlapped particles of radius R and set contact radius as 1.1R,1.2R, respectively. Will EDEM calculate identical contact force? What's more, I wonder if contact detection is based on contact radius. For example, EDEM will start calculating contact force between two particles if two spheres of contact radius have overlap?
I would like to know if my understanding is correct and what if I use different contact models. Currently I am using H-M with JKR V2.
Jason
