I want to write a vector to an excel file in EDEM API. So I installed an external library named libxlsxwriter in visual studio environment and use functions by including a header file: #include "xlsxwriter.h".
Then I wrote a function based on the library,like save_excel(vector_to_be_saved). This function works well in a seperate cpp file, either debug or release in Visual Studio Local Windows Debugger, it creates an xlsx file with vector information. In my API project, I call this function only once at the stopping function:
void CFieldQuery::stopping(NApiCore::IApiManager_1_0& apiManager)
save_excel(Agglomerates_over_time);
However, I could not load the generated dll file from my api project to EDEM. When I was trying to load the dll, this error message below shows up. But if I comment the function save_excel(vector_to_be_saved), the dll could be loaded, so I believe the problem is solely caused by this function. Could anyone figure out what is wrong with my code?
