Hi, my name is Kesit Bayu
I have finished the CFD analysis, then I try to read the analysis results using the hypergraph, why does the hypergraph show the time variable? whether in this case is iteration? Is there any suggestion to read the analysis result from hyperworks cfd so that the reading is more accurate? I am also still confused in choosing the turbulence model. Any suggestions in this case?
thank you
Best Regards
