I am doing a non-linear structural analysis in SimLab. I have defined multiple load cases for a single structural analysis.
I am facing the problem when I try to modify only one load case from all the load cases that i have defined (6 total). The result data for rest of the load cases is also deleted, even though I only edited one of the load case.
Also when I try to solve only one load case, the Simlab solves all the defined load cases simultaneously. Is there any option to solve or update only specific load cases so the rest of the load case have their results saved instead of simultaneous solution of all of them?
I thank you in advance for support
