Hi expert,
How to import optimization results to Inspire Studio? I tried to import results file (.h3d) to Inspire Studio but it loss optimization part.
Thanks,
Tuan.
That is just a visual issue, not a geometrical one.
Double-click on the imported STL, in the panel find the Smooth buttonand its parameter which is 60 by default, set it to 0 and click Smooth.
This will solve the visual issue.
Regards,Antonio
.h3d file can be imported mainly for visualization or rendering of animations.
If you just need to work on a model coming from an optimization and you either needto work on the geometry/reconstruction or even on the visualization/renderingbut no animation is required, I would suggest STL.
Hi Antonio,
I tried exporting it to a .stl file but the non-design space has some changes. I want to maintain design space, and reconstruction for optimization part
Thank you for your help
