Weld fatigue life prediction?
Richard Smith
Richard Smith Altair Community Member
edited November 2023 in Community Q&A
Within my assemblies i need to conduct fatigue life evaluations on both base material and weld lines within HyperLife.
My fatigue environment is random vibration in nature therefore I understand I must utilize an FRF model with PSD input approach.
I note that because of this i can't use the Volvo method (as a PSD input is not an option) so i must use the Weld Certification tool approach (which I understand is an entirely different approach but this is generally preferred for my applications due to its simplicity).
I note that within the Weld Certification tool the only option to evaluate welds within a random vibration environment is to invoke IEC61373 Specification which enables the "Input PSD with FRF" option within the Load Map dialogue.
Without reading this entire specification standard I was wondering how IEC61373 is implemented? Is this specification equally valid for Steel welded structures and Aluminium? Noting that the other option of Eurocode 3 (for Steel) is available (but not for random vibration) but Eurocode 9 (Aluminium) is not available as a spec option?
In other words, can i evaluate both steel and aluminium welded structures within HyperLife under random vibrations conditions using the Weld Certification tool and using only the IEC61373 specification?
Thanks for any assistance.
Welcome!
Welcome!
