Hello!
I am doing a CFD modelling of a plane with a pusher propeller attached to the back of the body, so I cannot introduce it alone in the cylinder of control (that will be afterwards the volume used to set the rotatory frame of reference), but with the final part of the body inside too. The propeller has only two blades, so if I want to establish a periodic boundary condition, it must be on surfaces spun 180º. But when I choose the option of periodic boundary condition, I select one of the two vertical faces as the source but no surface is then available to be selected.
How could I fix that?, or are there any other ways to define this boundary condition, taking advantage of the anti-symmetry?
