Reference frame to simulate rotation of a propeller
User: "Rafal Blasczykowski"
Altair Community Member
Updated by Rafal Blasczykowski
Hello all!
I'm new running with this software so I have a doubt.
I want to simulate the rotation of a propeller. So I import the propeller's geometry and then make a cylinder surrounding it. Then I subtract the propeller volume from the cylinder with Boolean>Subtract>Target-Cylinder + Tool-Propeller and set air as material. Then I use a reference frame (steady), selecting the surfaces of the propeller's previous volume as the moving body, and the axis. Then I run the simulation and I obtain this velocity contour.
It seems to be a photo of an initial instant of a transient simulation instead of a steady result.
Does anyone know why is this happening?
Thank you!
1 - 1 of 11
