I am using HyperView to plot my LS-Dyna solution files.
I have a large model with many components made of varying materials.
I want to be able to create a safety factor contour plot based on a components Von-Mises stress with relation to the components material yield stress.
I have read a few threads in this forum asking similar similar questions and I've noted that the standard answer seems to be "use the expression builder" within HyperView.
I've read though the help files but I do not seem to find enough information or examples on how I might go about creating my SF contour plot.
Within HV I create VM stress plot for the whole assembly. In the results browser I can right-click on the VM stress result and select "Create- Derived Result". This brings me to the Expression Builder where VM stress is already selected as "Table Component".
From here I'm not sure how to proceed. To be able to produce such a SF plot I would need the yield stress data for each material used on each component but this data only lives in the preprocess HyperMesh file or the LS-Dyna .k file, so how can I access that information here??
There is the "ADD Resource" button that seems to require an xml file, should I use this and if so how could i produce the xml file required?
Is it possible that an example or walk through on this topic could be provided as it seems a number of users are querying the same thing.
Is this even possible with Expression Builder, or HV in general?
The obvious goal here is to have a stress SF (or other output) contour plot within HV that can be animated or screen grabbed for report purposes.
SF contour plots seem to be a fairly standard output in many analysis products but I struggle to see it anywhere in HV?
Thanks.
Richard.
