Contact status is different on 2 components
Shiva Prasad
Shiva Prasad Altair Community Member
edited April 2024 in Community Q&A
I have created a non-linear contact surface between 2 components ,after solving when I check contact status on both components it is different ,how is it possible?.
For example consider 2 components component A and component B , when we create a contact choosing surface A from component A and surface B from component B , the contact status should be same on surface A and surface B, but it is showing different .
So I want to understand whether this is happening for my load case or it will happen generally .If you have documentation for reading contact status please attach that as well.
  • Rajashri_Saha
    Rajashri_Saha
    edited April 2024
    Hi Shiva,
    What you are observing is expected. The calculation of contact result on both side of contact interface involves projections and mappings. Hence a perfect match of results between two sides cannot be expected.
    To know more on contact status you can refer the below link.
    CONTF (altair.com)
    Thanks
    Rajashri
