i want to do a shape optimization to the ribs of a plate. The solver should vary the height of my rib along the plate. I have created a domain with all the nodes of the ribs in it, and now i want to create a shape where the height of the ribs is reduced, so i can save this shape and turn it into a design variable. The problem i have is, that whenever i move the handles of my domain, I've got the bottom of my ribs passing through my base plate. I already fixed all nodes of the plate in optimization > hypermorph > morph > set constraints, but still the mesh passes through rather than "compress" above the plate.
Is there any way to prevent that behaviour while morphing?
Thank You
