Error #15 negative jacobian
David_21639
New Altair Community Member
I want to calculate my meshed model, but the Program tells me that there is a Error#15, negative jacobian at one of my elements.
Tried to remesh it a couple times... but it doesn´t work...
What can I do to fix this problem?
I tried to set Param<Checkel_V1 to "no" but that didn´t solve my problem.
sincerely,
David
probably there's some part of your model that is failing the jacobian quality test, that even checkel_no can't ignore it.
Can you check your model for failed elements (F10 >> check elements)?
Find the ones with poor jacobian values and correct that region in the geometry or in the mesh directly, depending on your HM skills.
A video showing how to check and identify the failed elems:
https://www.youtube.com/watch?v=ldWR7RNLcgg
