Is it possible to open and work with a 2019 Hypermesh model on a 2015 Hypermesh license?
Recently, I cannot open the newer model on the older license because of backward compatibility.
Thank You!
Sincerely, David
You need a 2019 license to be able to access 2019 (and older) products.
Hypermesh is not backward compatible either. A 2019 file will only open in 2019 (and newer) Hypermesh.
You can export the solver deck and import it into any version however as a workaround. You will lose geometry but will have all your fea entities.
