I have two questions.
1. When using the Thermal model, the thermal resistance unit is Kelvin or Celsius per Watts.
but PSIM only has a model for electrical resistance. For example, if the thermal resistance is 0.3K/W, does PSIM just enter 0.3 ohms?
Do I also need a conversion to the temperature unit?
2. Can a motor model with above 3 phases of input in JMAG be imported into PSIM and used?
For example, assuming that I modelled a 6-phase input motor in JMAG, after extracting the jcf file and xml file, which are the data files of this motor, can I use the MagCoupler (DL) model in this case?
If you have a sample file for this, can I get some?
