Hello everyone,
I have made a project in Flux 2018 but now i have a problem. If i try to open the project it says 'open project: Execution failed'.
What can I do?
It is difficult to find what is going on without the project. would it be possible to zip the Flux directory (nameproject.FLU) and to send us this zip file so we can better help ?
Unfortunately I can't send you the project.
What else can I do?
I have almost the same problem, when Flux finished to slove my geometry the program close up and when i try to openned it after this it made the same error.
Someone can help me?
Hi everyone. i have the same problem and i've tried everything and none worked. does anyone know or figured out the solution?
