I am trying to estimate the Force it would take to break a rivet. I am applying a displacement load and am measuring the reaction force at a cross-section. However, I am getting 14.2 kN Reaction force which is very high.
The Rivet is made of steel (Tensile failure stress = 420 MPa) and it has a cross-section area = 4.58mm^2.
So, the max shear force to break the Rivet should be less than 420e6*4.58e-6 = 1.9 kN. This Rivet in reality should break under 1kN load.
I am attaching this simple example with this post. I am not sure what exactly is wrong with my setup; Or what should be the correct setup to estimate the force it would take to break the rivet.
Can you help and/or provide guidance to resolve this issue?
