A fatal error has been detected during input processing:
*** ERROR # 7007 ***
The run failed because automatic memory expansion has failed.
Currently allocated working storage is 8802 MB.
Automatic expansion failed to expand to 22933 MB.
The failed amount is the minimum required memory to complete the run.
Please verify whether the system has enough memory and rerun the problem.
Note that estimated disk requirement exceeded available space.
See WARNING 1971 in the output file.
but i have 174 GB free, I am doing FRF. I have reduced stress range. But still no change in estimated disk size
