I am developing an FE model of the human spine where I use the Ogden, Mooney-Rivlin material model (MATX42) for the intervertebral discs. I am getting some errors, and I would like to make sure I am using the right analysis settings. I defined an explicit analysis with the subcase option of NLEXPL, I am running the simulation in OptiStruct. The error I am getting is:
A fatal error has been detected during input processing:
*** ERROR # 5920 ***
Only the following solid elements are supported in explicit analysis:
eight nodes HEXA, ten nodes TETRA, and six nodes PENTA.
I understand that some of my elements are not supported by this analysis. As for solid elements, I have CPYRA (5-noded, unsupported), CHEXA (8-noded, supported), CTETRA (4-noded, unsupported). My questions are:
1) Is using explicit analysis my only option? To accurately represent discs, I will need to use the Ogden, Mooney-Rivlin material model. Is it possible to use a different analysis type where I can use this material model?
2) If using explicit analysis is my only option, how to fix the error I am getting? I have a very complex geometry and re-meshing unsupported elements are likely to be difficult.
Looking forward to seeing some help.
Best,
Riza Bayoglu.
